Another Suspension Issue
Looking for some help please. I have a 2006 LR3 HSE, 130k miles on it and I have a problem I am hoping someone in the group can help me with.
At 50mph the suspension drops in to access mode and I get the red warning light on the dash. Suspension fault and no special programs.
Switch off, pull the key, turn it back on again and every thing is normal. I can travel at 45MPH with no issues BUT 50 mph it drops again.
Can any one shed some light in this?
Thanks for the help
Thanks for the help
Check and make sure that all four tires match the tire placard on the door jamb.
A couple of good possibilities have been mentioned above, but I would recommend you get the system scanned for fault codes from a qualified Land Rover specialist. Whether that be the dealer or an independent shop that specializes is up to you, but most shops that don't specialize in Rover won't be able to access the Ride Level Module or know what they are looking at.
mx, think back....was that an amber suspension fault or red? I had one related to the steering-angle sensor as well but it was slightly different than a cross-articulation fault. The former is amber, triggered after a certain time (I think) and drops you to Access height. The latter is red, is triggered at a certain speed and drops you to bump stops.
For that matter, G Reeves, also think back and recall the precise effects of this failure.
dropping at 50 mph
Thanks for the help
Thanks for the help
TRIARII
Off Topic
09-09-2015 11:29 PM
