Anyone Installed an ARB Rear Locker on LR3
I heard that ARB has a rear locker available for LR3, anyone installed one yet? Would appreciate any input available, Thanks ARB RD218 Land Rover Air Locker LR3 Rear
Yes, but keep in mind that you also have to purchase an air compressor (and perhaps reservoir?) and find a place to mount it. Also, I don't know, but is the ARB locker an entire self contained differential or is it just a piece of hardware that you install inside your current open differential (more likely)? Probably still cheaper than purchasing a locking diff from LR and a locking motor and selling your old diff, but not as big of a difference as it seems at first.
Yes you make a good point, ARB Locker $1050.00 / ARB Compressor $299.00 / Installation $ 500.00, $2000.00 adventure. I think this is about half the cost of an LR rear diff with accuator motor & gives LR3 owners without HD package a great option for themselves to do what the LR3 was intended to do, 2/3 Offroad & 1/3 Onroad!
SORRY ABOUT THAT!!!!!!!!!!! By the way this ARB Locker is installed hardware to current non HD Diff & the compressor will run front & rear same time. After reading all these depressing posts for the last years that there is no option unless HD package & looking to the ends of the earth especially out here in SoCAL (Mall Buggies), I finally can pull the trigger on a LR3!
In Life All We Can Do Is Dream & Go To Work To Supply Them!!!!!!!!!!!!!!!!!!!!!!!!
I have a compressor mounted for tires and such. It's mounted in the driver's side cubby in the boot. I don't have a third row or 2nd row climate control (both by choice) so that's made life easy in terms of real estate for add-on stuff and dealing with the body join in the wheel well where bigger tires rub.
As for a front locker, I like to joke about it but I'm not sure how much help it'd really be. I mean with a rear locker and 4ETC would a locker up front really add that much more capability? If it were open front versus locker then yes I'd say it would be significant, but going from a Traction-Control front to a locker it's not gonna do much. Remember that if it's an E-locker it's probably going to turn itself off if you're in a turn, anyway, which makes its use-case pretty limited.
HD Package is nice. Turns out it needs a lot of maintenance (I'm on my 3rd or 4th rear diff, sad that I've lost count) but yes it's tough to find. I bought my LR3 nearly 10 years ago; ordered it and waited. It was a luxury to be able to do that...and checking the box for the $600 "HD Package" was a no-brainer.
