Apparently my A/C doesn't work...
Hey all! 2008 LR3. Milwaukee, USA. 88K miles.
It's starting to get warm here in Wisconsin and I tried using my A/C for the first time since buying the car over the winter. No matter what I tried, there were hints of some cooler air, but certainly not COLD A/C air. Looks like I need a recharge of sorts. Is this common for Rovers?
Anyone know what I should expect to pay at my local dealer? Or is this an easy type fix that should be done at any Midas-type store, or a local foreign car specialist?
Thanks!
Thanks!
recharge it every spring
I would not say I have not had any real problems with the HVAC system other than "noises", however every spring, I have the AC system recharged.
The dealer acts like it was down and charges me for a pound of C134A.
The work order usually says something like "500 grams present so recharged to 900 grams." I also get them to add that UV dye to help find leaks. The general feeling is that there are no real leaks present, the system just needs topping up. Go figure; I pay and stay cool for the two weeks of summer we normally have here.
It is just that I tend to almost die if the outside air temperature goes above 70F (21C).
I have a feeling this must be cold related, 10 year old vehicle, never taken any freon, checked once. Whine of course, fart cured for 400 bucks.. Just need to replace the A/C pump to cure the whining. My A/C has barely been shut off in 150k miles.
The Lexus, (Toyota) did have low freon this spring.
It is best to have it checked when the temperature is warm above 70 say..
LandRoverDisco03
01-31-2015 11:56 AM
