AUX Input- How to fabricate one?
I own a 2006 LR3, US model. It is the 'bare bones'model , as I call it. Here is the trick, the radio (land Rover brand)has an AUX output but the unit came with no wiring for it (the is no 3.5mm plug behind the console). How can I connect a female jackto the radio? I have taken appart the radio but I need to know exactly wich are the pins to connect the plug.
RE: AUX Input- How to fabricate one?
I am a new LR3 owner (5 days) and not to hi-jack this thread, but I plugged my wifes ipod shuffle into the aux jack and I don't hear anything coming from it. I turned the stereo to the aux mode. Is there something else i must do in order to hear a device through the aux jack?
Thanks,
Jason
Thanks,
Jason
Yes, the plug SHOULD be ther, but in the trim line that I have (basic) there is none. In fact, I took the cover off and there weresome unused plugs, but I am unebleto identify wich is the one that I should use to connect the radio. Itook the radioout ad again there are some pins on the connection plug that are unused but I don'thave a diagram to work with. The LR dealer was unable to providea usefull wiring diagram. Did you know that if you unplug the radio, the engine will not start? That is just way too much...
