Detachable tow bar - Land Rover Forums - Land Rover Enthusiast Forum
Old 09-01-2012, 10:58 AM
Junior Member
Default Detachable tow bar
In the manual this looks like this is standard equipment, but unfortunately it appears the LR3 i picked up used does not have this piece. Is this supposed to come with the vehicle as standard? Any suggestions on where to pick one up?
Old 09-01-2012, 09:59 PM
bbyer's Avatar
Senior Member
Default Not standard and not eBay.
The detachable bit and wiring are now standard on the LR4 but no so on the LR3. If there was a hitch when the vehicle was traded in, most dealers remove it and sell it back to you for about four hundred dollars, or new, about six to seven hundred; also there is the trailer light wiring harness.
The link below is to some files related to the hitch and hitch wiring.
DISCO3.CO.UK Photo Gallery - NAS Trailer Socket Pin ID and Wire Colours
I would recommend you stick with the official LR wiring harness as the harness is an extension of the trailer sensing bits that tell the air suspension to sort of freeze up as well as telling the backup sensors to shut off and some other computer related towing stuff.
If you are purchasing the detachable thing, buy the short one for the LR4 rather than the longer plough type of the LR3. Also be wary of eBay on the old style ones as LR did an upgrade or two on the locking mechanism. See the file link for details.
If you are going to tow a lot and clearance is not a concern, consider a Curt bolt on - cheap and simple - nothing can go wrong and what we are used to.
Thread Thread Starter Forum Replies Last Post
Detachable Tow bar question Netorius77 LR3 3 07-30-2013 10:48 PM
LR3 2009 - 3rd Party Tow Bar Options? Darrinj123 LR3 3 11-18-2008 06:58 AM
Tow Bar Help Please scottma Discovery II 5 11-14-2008 10:36 PM
To tow, or not to tow... S4poor Discovery II 12 02-10-2008 10:15 AM
97 Disco; Can it be towed on all 4 wheels with a Tow Bar? azdesertdog Discovery II 1 12-16-2006 11:54 AM
Tags
bar, buy, detachable, hitch, land, lr3, lr4, mechanism, range, rover, sale, short, tow, towbar, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
