Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 02-14-2011, 02:31 PM
Junior Member
Default Enable Nav input on the go by cutting off vehicle speed signal to Nav module?
Hi All,
I have a 2008 LR3 that can't use the Nav Hack to enable the Nav Input on the go b/c of the firmware update. I found the wire diagram for the main Nav Module and I see there is a vehicle speed wire going from the ABS system to the main Nav module. My thought here is to put an in-line switch onto this wire feed so when in the off position no speed info will be sent. I'm assuming its this feed that tells the Nav to enable/disable the buttons by moving.
Anyone done this? Am I on the right track?
See page 5 of the wire diagram:
http://lr3tips.files.wordpress.com/2...mentsystem.pdf
Old 10-02-2011, 12:47 AM
Junior Member
So did you try it? Did it work?
Tags
2008, 2010, 2011, 3, discovery, forum, hack, input, land, lr2, lr3, nav, navigation, rover, signal, speed, vehicle, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
