Engine oil or coolant leak ? Or
Certainly looks like the VCT seal needs replaced. Check out this link for further details on part No and fitting new seal, https://landroverforums.com/forum/lr...-engine-73818/
Alrawas (02-11-2017)
(PCV also is leaking) so I desided to do service by myself . I took out the under shield skid plate pls have a look
So after that I drained the oil and I measured it to now how much exactly was in the engine and it was 5.5 liter ! Which is equal to 5.81178515 US quarts. Is that normal ? Anyway I don't now exactly the leak is from where , engine , transmission ! Can you please tell me what I can do before I take it to the dealer 💸! Is there a way to measure the transmission oil ?
Oil capacity is listed as 8 quarts, so yes that is low.
Does the fluid leaking have a smell to it? Transmission fluid smells different from engine oil. It also will probably have a lighter color to it (not as black) if you wipe it with a white rag.
ZMonet
06-24-2016 04:00 PM
sadain
05-03-2012 09:40 PM
