Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 01-09-2012, 10:30 AM
PJH PJH is offline
Junior Member
Default Intermittent Wipers
Hello, I am new to the forum, looking for some assistance with Intermittent Wiper problem. Any help is greatly appreciated - have searched forums with no luck.
I have a 2007 LR3 SE w/57K miles. Vehicle is equppped with rain sensative wipers.
I have never had a problem until two weeks ago. Now wipers do not work at all in intermittent mode. Fornt and rear wiper can be activated manually by pushing switch down for single wipe or setting to high mode. When you pull the switch down to activate a single swipe, the wipers stop as soon as you let go of the switch - they do not return home to the bottom of the windshield. Same thing happens if you shut off high mode, the wipers stop wherever they are on the windshield.
If anyone has had this problem or has any advice, suggestions would be very much appreciated.
Thanks!
Old 01-09-2012, 08:09 PM
Senior Member
if the wipers stop wherever they are then the motor is bad itself. seen it a few times.
the park switch has failed.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-10-2012, 06:19 PM
PJH PJH is offline
Junior Member
Thanks. Very big help, the closest LR dealer is 90 miles away. I will get one on order and report back.
Thanks again
Tags
2000, back, intermittent, land, lr3, mamaul, manual, replace, rover, setting, shut, wiper, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
