Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 08-11-2011, 07:22 PM
Junior Member
Default LR3 newbie here...couple of questions
1- my AC vent is making a chirping noise that's driving me crazy! Any solution for that...that I (myself) can do??
2- I saw a picture of a silver LR3 with a LR4 "looking" grill. Also, it had BFG AT KO tires. Basically it's exactly what I want my car to look like...but I cant find the pic or who it was??
3- where do you get a a LR4 grill like that? I realize it's not really an LR4 grill....
4- If I get my running boards removed, will it leave VERY noticeable marks where the factory had to cut the plastic when they installed them?
Any and all help is GREATLY appreciated!! Thanks!
Old 08-12-2011, 07:56 AM
Junior Member
Anybody have any answers to these questions?
Thanks
Old 08-12-2011, 12:57 PM
Senior Member
the noise you are hearing is the blend door actuator rubbing, there is an update "grease" that quites the noise. remove the upper glove box and you can access the blend door motor to spray some wd40 or silicon.
Old 08-12-2011, 01:07 PM
Junior Member
how do you remove the upper glove box? is this simple?
Old 08-12-2011, 02:40 PM
Senior Member
its just couple of clips that hold it in place but they are strong clips so will take good effort to just pull it off. pull down the door and with a pick tool yank the assembly out. you can also remove the passengers ride side air vent for better access by also just pulling on it
Old 08-12-2011, 06:05 PM
Junior Member
ebay usually has good deals.
__________________
05 lr3 se HD 82K
MODS: Yes
Old 08-14-2011, 06:45 AM
Senior Member
no paint marks but the exterior mouldings have to be cut into on the bottom to get them on.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
air, blend, box, chirping, chriping, door, glove, grill, lr3, lr4, making, noise, remove, silver, vent, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
