Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 03-02-2011, 11:08 AM
Junior Member
Default P0209 OBD II code
The check engine lioght keeps comming on and the code is P0209. Anyone know what this is or how I can permanently disable the check engine light? The dealer doesn't know what it is and my OBD indicates it is for thermostat temp too low and online search results say (some of them) it is an injector problem for cylinder 9, which it can't be becuae I have a 2005 LR3 4.4 V8. Any help will be appreciated!
Old 03-02-2011, 11:50 AM
Senior Member
P0128 (Coolant Temperature Below Thermostat Regulating threshold)
sounds like your thermostat is stuck open.
http://www.scribd.com/doc/45477748/L...eplacement-DIY
__________________
5 Corners Auto Repair - Long Branch NJ - 732-642-2968
Land Rover Master - ASE Master - ASE Advanced Level Specialist
Old 03-03-2011, 10:34 AM
Junior Member
Thanks for the info. I did not read the code correctly because the screen on my OBD II is so small. The code is P2099. I gather this is a computer download update. Is there any reason to get this done right away or can I wait? I live a long way from the dealer.
Old 03-03-2011, 10:36 AM
Junior Member
Is there a different set of codes that apply to LR than are displayed on basic OBD II? Is that why you stated code P0128?
Tags
2005, codes, ii, land, location, lr2, lr3, obd, obd2, open, p2099, ports, rover, stuck, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
