P2096 - Stumped
P2096 - Stumped
I've got a P2096 Post Catalyst Fuel Trim System Too Lean (Bank 1) code tripping my CEL. It suddenly appeared during a long highway drive a couple months ago. Cleared it and it didn't come back for a while, but then came back on another long highway drive and persisted. Since my previous engine burned a lot of oil right before it died, and I got some catalytic converter efficiency codes (fixed temporarily with O2 spacers), I figured the catalytic converter was gone and so I just had a brand new OEM one put in (no O2 spacers). The code came right back. It drives fine, with no hit to fuel economy.
I can't find anything on this code for Land Rovers except a few random references with no resolution. Not sure what to look at next. I have a few data logs from my IID tool, but not sure what to make of them.
Here are the voltages from the bank 1 rear O2 sensor at idle. Doesn't look particularly lean to me?
I also checked the fuel trims, but they all look normal (in single digits).
Here's what I'm thinking:
1. O2 sensors are bad (likely rear, but not sure).
2. Leak somewhere in the exhaust manifold or gasket letting air in (would think it would push air out given the pressure?)
3. Leak somewhere after the MAF (why would this only trip a bank 1 code?).
Any help or direction would be appreciated!
Last edited by djkronik57; 03-24-2017 at 07:34 PM. Reason: Added conditions for graph.
