Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 01-10-2012, 06:38 PM
PJH PJH is offline
Junior Member
Default Parking Sensors not working
I have a 2007 LR3, the front and rear parking sensors recently stopped working (three months ago). Most of the time the system is dead...no beeeps, no light on the dash, and when you push the pdc button on the dash nothing at all happens.
Occasionally (once or twice a month) when I start the car, I head the beep and the sensors work perfectly. Next time I get in the car, they are not working again.
Any thoughts or suggestions would be greatly appreciated.
Thanks in advance.
Old 01-13-2012, 12:35 AM
Junior Member
I had the same intermittent issue. Fixed by replacing battery. The battery had a few dead cells and wasn't providing enough juice on start to properly start all the accessories.
Old 01-13-2012, 04:20 AM
Senior Member
IMHO, even if you don't purchase the battery from them, have a store test your battery volts / alternator amps / starter drain for free. In addition to the dead cell issue, it can detect an alternator that has a bad diode or other internal part, which would keep it from charging the new battery fully.
__________________
Old 01-13-2012, 08:53 PM
Senior Member
You could have the codes read to see what its saying.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-13-2012, 09:17 PM
Senior Member
At the same auto parts store. Where you can buy your own basic reader as well, a very handy tool indeed.
Old 01-14-2012, 04:52 PM
Senior Member
No, you need a hawkeye or similar product to read anything on these vehicles.
__________________
Old 01-15-2012, 11:40 AM
PJH PJH is offline
Junior Member
The_cud...Thanks for the help!! Can't tell you how apreciated it is. It is 16 degrees here in PA today, the battery seemed weak so I replaced it. The parking sensor problem went away.
If I had 100 guesses, I would have never thought it was related to the battery. In fact, until this extremely cold day, the battery seemed perfect.
Thanks.
Tags
2010, backup, bad, land, lr3, park, parking, pdc, problem, range, rover, sensor, sensors, work, workin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
