Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 01-07-2011, 04:36 PM
Member
Default pulls to the right
My LR3 05 pulls to the right when I travel at low or high speeds.I have new tires and have had a front end alignment and new both lower control arm replaced. So what could be wrong?
Old 01-15-2011, 09:52 AM
jimbiram's Avatar
Senior Member
Check tire pressures, and recheck the alignment. Not everyone knows how to do a proper 4 wheel alignment on the LR3. Also, you might try rotating the tires. I have had bad tires installed that cause that as well and you may have to have it "trued".
__________________
Every Day is a Good Day Surfing...Some are just better than others...
Old 01-21-2011, 03:08 PM
Junior Member
Mine was like that when i test drove it and part of the deal was for them to align it before i picked it up. They did and it was even worse!
I bought it at a ford dealership, when i went and picked it up the second time, it was bang on.
Apparently they had to do the alignment with the door open so the truck would stay at the higher suspension level vs when it comes down after the truck is turned off.
Tags
alignment, brand, end, front, land, lr3, pulling, pulls, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
