Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR3
Register Forgot Password?
Old 11-27-2011, 09:33 AM
Junior Member
Question Query re LR Disco 3 '06
Nearside lights aren't working, brake light is. Reg plate light not working either. Replaced all bulbs - nothing. Bought replacement fuses as the relevant one had gone. Installed. They keep blowing. I have two problems. 1. I am a childminder and so being without my car/taking it to the garage with 3 under 5s in tow is a nightmare, as is trying to get a courtesy car that will carry 7 children! 2. I am skint - is there anything I can do (or, preferably, get me other half to do!!!) to resolve this problem? What might be making the fuse keep going every time a replacement fuse is put in? Any help would be very gratefully received thanks!!!!
Old 11-27-2011, 09:39 AM
Philip Lawrence
Send a message via Skype™ to Spike555
You have a electrical short somewhere.
I am not a electrical person so I cant help you much more than that.
I moved you to the correct section on the forum, the LR3 section.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 11-27-2011, 11:04 AM
Senior Member
are you sure you installed the double filament bulbs. But you have problem with wiring shorting out,
Does the brake lights work and does the parking lights work as well or is it just one side doesn't work?
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 11-27-2011, 01:43 PM
Junior Member
Hiya - I don't know what type of bulbs, I will check. The brake lights work but the brake light and numberplate light don't come on at all.
OH did say it was quite wet in the rear bulb quarter - is this a typical problem???
Old 11-28-2011, 01:18 AM
Junior Member
The problem is on one side of the vehicle only. The brake light works, all the other lights don't. What do you mean by parking lights - not familiar with this term?!!?
Old 11-28-2011, 01:41 AM
Junior Member
My other half says he took the bulbs that appeared not to be working and got the same type so we have to assume that they were double filament.
Old 11-28-2011, 07:56 AM
Senior Member
if the fuse blows immediately then look for wires, if it takes a while then wiggle wires at the tailgate and the light to see if it blows.
__________________
Tags
auto, blowing, forums, fuse, lamp, lr3, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
