If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Diff failures are quite common on the LR3. Its due to two things: (1) the internal coating on the diff housing flaking off and the flakes finding their way into the bearings and ruining them and (2) moisture finding its way into the diff housing and rusting out the bearings. Both are preventable by changing your diff fluids once a year vs the ones every 50K or 75K Land Rover recommends. Both the front and rear diff are prone to this, but more seem to happen on the rear than the front
So when the air suspension develops a fault are going to put four new bags in it one month, a compressor next time, and then four sensors, followed by a few valves and finally an ecu cause its more satisfying to know you stayed away from the professionals despite the cost.
You see something as simple as a test drive with a shop foreman and a simple inspection of the vehicle for less then a half an hour would have garnered the same fix for alot less. But hey, I am just a simple technician, Its nobody's business if you cut your nose to spite your face.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Had car towed to dealer to find out front end noise . Dealer called today and said we think noise is coming from the transfer case . Price to fix 3,800 . They still can not tell if the front dif is bad . So dealer is no better than my local shop . So more parts ...
