If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
When removing/installing spindles, cover the lower ball joints with a rag or 2 to prevent the lower ball joint from cutting the cv boot.
Tie the front driveshafts up so they don't hang (the inner cv joints like to pop apart)
Make sure you have a sawsall and lots of blades to cut out frozen camber/caster bolts.
Don't damage your catalytic converters with your hammer
Don't install the control arms upside down and backwards. You'll hate youself.
Install NEW camber/caster bolts and hardware
Be careful when reassembling and tightening the camber/caster bolts, and when trying
to adjust them. The locating tabs on the chassis are fragile and damage easily.
__________________
Mike G
It's never over with a Rover...
06 LR3 W/G4 Accessory Package 94,000mi
04 Disco 2 128,000mi For Sale
99 P38 Bosch 70,000mi
66 GTO Convertible 427 Chevy
08 Buell 1125R
01 Kawi Concours
mark the camber bolts and reinstall them as best as possible.
Drive the vehicle at least ten miles and the perform the alignment.
You will need an outside shop, the trick to doing the alignment is to let the vehicle run with the door open after its in its regular position. then you can align the vehicle correctly.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
