After 11 days in the dealers, the replacement of 2 x EGR Valves and an overhaul of the front diff, the dealer finally found the gear box and gave it a flush with new oil. This did not work at first so they flushed again and replaced the filter. This was not initially a total fix and the dealer gave up and refunded all my payments. After 500 km the surging has now gradually disappeared and it appears that replacing the oil and flushing the gearbox has fixed the problem. I have a local mechanic who has just moved to Australia from UK where he was trained at the Landrover factory and specialises in gearboxes. He says this is a common problem and that gearboxes are NOT SEALED FOR LIFE and the factory, internally, recommends gearbox oil replacement every 50,000 miles/80,000 km. Makes sense.
I also checked the air intake valve but it was clear and working well.
