Suspension fault culprit?
Ok I've been getting the abs hdc dsc faults on and off for the past year. Every time I would drive 15 or more continuous miles I'd get the faults, suspension drops to access only. If I shut off the lr3 and restart it, the faults go away. I've checked/changed everything. Brake bulbs, brake switch, new battery, checked and changed abs sensors, checked wires for corrosion on passenger and driver side. Also the wires on driver side by hood release. So today I decided to check my compressor and I sprayed some soap water onto the hoses and collets and where the two lines go into the front of dryer the soap water was fizzing, bubbling. Would this cause a suspension fault? Or do these compressor leak like this? My truck's suspension doesn't drop down overnight so thats why I never checked my compressor. What's the fix? Do you think it drops every 15 miles or so because the compressor is trying to compensate/keep up with the leak? I've included a video below. Thanks.
But if I shut the truck off and restart the faults disappear and suspension is normal again. It's usually every 15 plus miles it faults.
kbarker27
10-13-2023 04:03 PM
tornado_735
03-01-2009 08:57 PM
