SUSPENSION FAULT - No Action Required???
I'm curious why replacing a brake lamp would cause a problem. My (2005 LR3) suspension fault light didn't come on until a day or so after I installed the trailer light harness, which connects into the the driver's side rear lamp assembly. While I was crawling around under the rear of the vehicle I noted a heavy weight hanging on the the rear frame, which I'm sure I moved around. After this the amber fault light came on, but everything seemed to be OK otherwise. Then towed a trailer and while doing this the fault light came on and it would not let me lower the vehicle. I figure this was normal due to the load, but since then I can't lower the vehicle, even though I'm not towing and I pulled out the hitch receiver.
Those weights are vibration dampers, or some other form of agricultural method of doing something to the mechanics of the truck.
They cannot possibly have anything to do with electronics.
Why you installed a trailer harness and got troubles is as weird as my changing out the battery and getting strange faults.
Is this making us want to go back to Lucas? I'm getting nervous about the new LRs when electrical faults are so common and so random.
Didn't think the weight did anything electrically, but considering the posts that mention the topic of of balance/sensors I wonder if I confused the beast by moving things and then towing the trailer. (the fault light went on before I towed, but it stopped going into the low rise setting while towing and then stayed that way afterwards).
Any strange warning lights coming on, start by checking battery voltage and then alternator output as these are critical and can throw the system into a complete tizzy. Simple stuff first, particularly if it is no cost!!!
Apologies for the rainy day ramble.
steering crooked vs red light suspension??
dear please just tell me the steering crooked make red light show? my car is lr3 and i make a line up on workshop then after show this red light but compressor is good! by the way the steering wheel is little crooked yes! please help me
My 05 LR3 (105K miles) recently has been showing a suspension fault warning. Exact message is "Suspension Fault - Normal Height Only" and the red suspension warning indicator illuminates (not FLASHING). Checking the vehicle manual under the message center, it states that there's "NO ACTION REQUIRED" needed. Under the warning indicators, the manual states the same unless it's flashing (in this case, it is advised to drive slowly and seek qualified assistance). What gives? I've been having this issue for the past three weeks and I've been driving the vehicle still -- it seems like there's nothing wrong at all even when the warning light/message comes on. Most of the time, the message/warning light comes after a few minutes of driving but once in awhile, it doesn't come out at all. I'm really confused. I'm ready to take it to the dealer but wanted to know what the issue is or what are my options are. I live in Italy where it's very expensive to have repairs and takes very long to accomplished. I'm trying to avoid that if all possible.
thanks
kbarker27
10-13-2023 04:03 PM
Arth111
02-26-2022 06:28 AM
06Range
05-08-2013 09:01 PM
tolia5
08-19-2012 04:14 PM
