temp sensor or VCT?
temp sensor or VCT?
Have an 06' LR3 with an ambient temp sensor fault.
have no temp reading on the dash. About to pull the bumper and change out the sensor, but I noticed the car seams to have a shake in the seat, idle is steady but I felt like something was wrong based on the vibration.
checked on Autologic and it's giving secondary causes for the temp sensor fault as the VCT solenoid on bank 1.
anyone know how these are related?
I don't remember the code number, but it was for ambient air temp sensor. Turned out to be a fuse, but I was asking because the engine has a lopey idle. RPMs are steady but the idle is lopey.
Autologic was showing the VCT as a possible secondary reason(actually third reason), so I was trying to see if there was a relation.
Now I need to figure out the lopey idle, but there are no codes.
If there are no misfire faults set, it could be normal engine vibrations that you are feeling from collapsed engine mounts? If you can feel it in Park at idle, use a floor jack and a block of wood to gently lift up on the oil pan (take some weight off the motor mounts) and see if it changes.
good suggestion!
thank you
twilightcall
03-04-2018 06:55 PM
rrbc
11-13-2009 04:59 PM
