Vibration between 30 mph and 60 mph
Hi Guys,
I'm hoping for some help with my latest LR3 mystery. I have a drive train vibration when accelerating between 30mph and 60mph that sounds kind of like a wheel that needs balanced but is not a wheel issue. It is definitely a drive train sound, it mostly goes away when I take my foot off the gas and no amount of turning or hard driving affect it. It is a fairly alarming sound and is getting worse. I've been trying to track it down for about 6 weeks now.
A local Indy told me it was the center carrier for the rear drive shaft. We replaced that with a new unit and the sound is still there. (The old center carrier looks fine as well, should have inspected it myself before hand) I also took it to the tire shop and asked them to rotate and balance and inspect all four tires. Which they did and found no issue. It sounds to me like the noise is coming from the front or below the driver seat. Rotating the tires did not move the noise from front to back. Also, the front Diff was replaced last July. It was replaced at this same local Indy shop which I have completely lost confidence in.
Do you guys have any ideas what could be making the sound? I've inspected the front drive shaft and I'm leaning towards it being the source but I cannot see any issue with it. There is a very small amount of play in it when pushing it from the front of the vehicle to the back and no play in it when pushing it up and down. Is it possible that it could have been damaged or installed incorrectly when the front diff was being replaced?
Any ideas are greatly appreciated. Thanks!
Has anyone replaced their front drive shaft? It looks like I need to remove the cross member where the transmission and transfer case mount, and I need to remove the passenger side catalytic converter. Thanks!
Had a bad vibration right around 55-65 mph and it ended up being the tire pressure was too high. craziest thing I ever seen but once I dropped it down to 32 PSI everything went back to normal. I replaced a lot of bearings and did a lot of adjustments that probably weren't needed but at least now I know they are done.
