Warning light
Yeah we are not supposed to have that. You may have flashed a firmware that is for non-NAS vehicles. If you actually have the heater (I believe only the TDV6 was fitted with the wabasto FBH), check the fuse box in the engine bay for the same symbol. You might be able to make the warning light go away by fitting a fuse in that slot.
I have the slot but not the FBH nor a fuse fitted.
Yeah, that will do it. Probably comes on with your lights now, right? The newer firmware is supposed to be for cars that have a "lights on indicator" in that spot... But on your car, there's a fuel burning heater inductor that lights instead.
Fuel Burning Heater - DISCO3.CO.UK Knowledge Base
easiest way to explain
little heater that siphons off diesel fuel to warm engine coolant for better cold start running and to immediately turn on cabin heaters for comfort.
