Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > LR4
Register Forgot Password?
Old 12-23-2010, 06:45 AM
Junior Member
Default LR4 Daytime Running Lamp
I had the dealer enable the Daytime Running Lamps (DRL) in my 2010 LR4. As I had experienced with a Lexus, I thought the direction lights would be on when the engine is running. To my dismay, I discoverd later that the headlamp low beams illuminate. I then checked the owner's manual and it's noted in there.
I didn't yet ask the dealer but does anyone know if the DRL programming can be isolated to the front direction lights. Seems like a complete waste to have the Xenon headlamp constantly on whenever the engine is running.
Old 12-24-2010, 02:08 AM
Member
I did this about 3 weeks after I got my LR4 and experienced the same thing - Low Beams are always on
I actually wrote to Land Rover in NJ and they indicated there is no way to just get the LED's on using the DRL. You have to manually switch to the accessory lighting.
Rgds,
__________________
BD
NEW - 1997 Disco SE - 148K Miles - Getting ready to modify it for wheeling!!!
2010 LR4 HSE LUX PLUS - Nara Bronze
Extended Roof Rails/Crossbars & Ladder
Old 12-24-2010, 02:30 PM
Senior Member
and not all lr4s have the led package. you have to have the lighting package not a regular LR4
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 12-25-2010, 04:51 AM
Junior Member
I spoke to a very reliable service person at Land Rover who mentioned that they've had a few complaints about this issue. He also mentioned that perhaps if enough owners complain to Land Rover they might do a software reprogramming to correct it. However he's not sure if it can be done.
__________________
LeFils
2010 LR4-HSE LUX-BLACK
Old 12-31-2010, 01:01 PM
Junior Member
Daytime running lights in the UK mean something different to the US. In the UK (and most of Europe) it's illegal to show yellow lights (on all the time) on the front of a vehicle like we have on US cars. They they use lo-beam instead.
Having said that, the LR3 has yellow side marker lights on the front, and I believe on non-us spec vehicles they still have the bulb holders but just dont fit the bulbs in them.
Looks like they were trying to save a few bucks with the LR4 and did away with the option all together.
__________________
Bill
Past:
1979 Series III 88"
1972 Range Rover Perkins Diesel conversion
1985 Range Rover V8
2000 Freelander
2001 Discovery Series III TD5
Current:
2006 LR3 V8 (68k miles)
Tags
complains, daylight, daytime, discovery, enable, forum, lamp, lamps, land, led, light, lights, lr4, programming, rover, running, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
