Powder coat vs painted wheels
I sold my Evoque with black powder coated wheels and they were beautiful. No chips or scratches regardless of the weather or terrain. Keep them waxed and everything just slips off like they were teflon coated. Cost is about $650 for all 4 if you take the wheels in to have them done, more if you take the wheels and tires in and they have to break them down and re-do them. Those are San Diego prices so you may have better or worse in your area. Dealer charges about $1300 for same service.
In my business we deal with customers who powder coated parts large and small. Parts are sprayed then baked at 300-350F for about 20-25 minutes. That is really not very hot when thinking about metals/aluminum. You should be just fine. Powder coating is significantly more durable than painting.
350ºF is enough to adversely affect the strength of an Al wheel.
Do your own homework and draw your own conclusions (I'm not interested in getting into another keyboard battle over this), but I've seen the end result of powder coating wheels enough times personally to stick with painting my wheels.
Racer X is correct. Many aluminum alloys are precipitation hardened. As precipitation hardened alloys age, they loose strength. Heat would only accelerate the aging process, even if it is only 350°F.
That being said, lots of people powder coat aluminum wheels and I wouldn't hesitate to do it myself. I'd be more concerned if I were running low-profile tires though.
Powder coating any aluminum alloy wheel will progress the aging process to a point where the wheels lose most if not all of it's ductility, resulting in a very brittle wheel.
When you side load a wheel (like when you're cornering), even though it's not apparent, the spokes will deflect ever so slightly. After powder coating, however, that deflection will produce a micro crack, which will continue to grow with each deflection, until...
If you're really unlucky and don't catch it in time, the cracks continue to propagate until the wheel separates from the center. I've seen this happen at more than a few track days, never with good results.
