3 gauge dashboard cluster installed
I did not really take any install pictures it’s a mess of wires, but I got everything from glow shift.
52mm gauges, oil pressure, oil temp, water temp, also need and adaptor for the oil filter to read oil temp and pressure. A 32mm coolant water sending unit adaptor. The pod is a $13 generic pod that fits on the dash held in with 2 wall screws with the push through wall spreading wing nut. Everything again was from glow shift, not the greatest quality but I like it just fine.
Just one tip when running wires through the fire wall drill a hole and use a pass through grommet. My old oil pressure unit only lasted 3 years till it sliced through the wire.
03discoman
01-14-2010 09:11 AM
