Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 07-28-2010, 09:40 PM
Junior Member
Default Can I remove the ABS
I want to know if the ABS system can be removed and a brake proportioning valve installed. It on a disco 96 that we have turned into a buggy. Not only do I not need the ABS, I also have no room to mount it. If it can't be removed can I run long lines from the master cylinder to the rear and mounted it in the back. I know the wires will also have to be spliced.
Old 07-29-2010, 06:48 AM
antichrist's Avatar
Senior Member
The D1 already has a proportioning valve, that's the same between ABS and non-ABS systems.
You need to go from this
To this
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 07-29-2010, 09:10 AM
Junior Member
Can I use the old proportioning valve or should I buy an adjustable one.
Old 07-29-2010, 11:02 AM
antichrist's Avatar
Senior Member
Like I said, it's the same proportioning valve on ABS and non-ABS Discos.
__________________
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 08-01-2010, 06:50 PM
Lee97Disco1's Avatar
Member
Default ABS Removal
Yup-yup,
I yanked mine out this weekend. My ABS Modulator wasn't suppling fluid to my front calipers. I did not want to spend the $2300 on a new one or the $750 on a rebuilt one. I went to Auto Zone, purchased 6, 12" 3/16 steel brake lines with compression fittings preinstalled. You will also need 1, 3/16 brass compression Tee. You can borrow the pipe bender & flaring tool from Auto Zone as well. You will need to go purchase a small pipe cutting tool from Home Depot, Ace or Lowe's. If you haven't downloaded the Rave manual from the New members section do so and follow the diagram provided inside it. I used the Modulator mounting bracket to relocate the Brake Pressure Regulator to. I used the same mounting bolt as well. Just make sure that you get a good flare on the pipe that you trim or it will leak and you will have to go back and reflare them. Also make and install a jumper wire across the two-wire pigtail that you unplug from the modulator and remove the ABS fuse from under the steering wheel. Hope that helps.
http://www.landroverforums.com/forum...709576&thumb=1
Lee McKinney
'97 LR Disco l
Old 08-02-2010, 09:54 AM
antichrist's Avatar
Senior Member
Quote:
Originally Posted by Lee97Disco1 View Post
Yup-yup,
Do not use compression fittings on brake lines. It's totally unsafe as they are not designed for use with the pressures generated in a brake system.
__________________
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 08-02-2010, 07:23 PM
lordmorpheus's Avatar
Senior Member
I don't think he meant compression fittings, even though he called them that. The flaring tool makes me think he used the proper brake line unions and nuts.
Using a flaring tool to create an inverted flare, or bubble flare, or whatever you prefer, and then screwing the then "nutted" lines into a union or tee is perfectly acceptable.
However, compression fittings (fittings that use a compression ring and compression nut) are NOT SAFE FOR BRAKE LINES!!!!
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Old 08-02-2010, 08:23 PM
antichrist's Avatar
Senior Member
Probably, but I don't want to make assumptions with something as critical as brakes, also when someone else will read it.
__________________
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 08-02-2010, 09:09 PM
Junior Member
Will this f up computer or traction contol
we will be running mostly sand but might put it on a liitle ice up north
I can make the abs unit fit if I need to but not happy with the abs on my 98 disco
so if others have done this let me know
thanks for everyones help
Old 08-02-2010, 10:21 PM
Member
You are right. I did not use "compression" fittings as most auto parts stores dont sell common household plumbing supplies. I am sorry that I miss-spoke. The disco is still doing better than ever.
__________________
S. Lee McKinney
1997 Discovery 1
Upgraded Air intake w/K&N
Flowmaster
4.5" lift (no pic yet)
1.5" Wheel Spacers (no pic yet)
Complete Pyle 1500 watt sound system
Hydrogen Hybred w/ Tornado assist
Tags
97, abs, d1, delete, discovery, eliminate, fuse, land, modulator, nonabs, remove, removing, rover, system, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
