If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Has anyone seen or know anyone that has a Devon 4x4 rear bumper for a D2? thinking about picking one up as my stock rear bumper can't take another hit or it will just fall off. Also wondering about picking up the lights to fit, wonder if i can find some aftermarket round LED's to fit because the kit is over $100.
yeah that is the kit im looking at. i guess $90 is better than $110. I need to get the rear bumper sorted it's a mess. sad you don't see as many used rear bumpers for sale as you do fronts. proves my theory that most people get off-road gear for show and no go.
__________________ -Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
try harbor freight last time I was in the store they had round led retofit lights(cheap),
Also check 18 wheeler supply houses on the web, the big thing on 18 wheelers these days is to convert to leds. You would be surpried how cheap some of the stuff for 18 wheeler are compaired to an assessory shop.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
that is exactly what i was thinking. i see a lot of trucks on the road with round LED's in their bumpers, figured i'd post here and see if anyone else did the leg work already.
Keep in mind that if you use LED lights your blinkers will blink fast just like when a bulb is burnt out because the LEDs have to low of a resistance and the system thinks a bulb is burnt out.
Your turn signals flash at the correct rate based on electrical resistance.
yeah im friends on facebook with him as well. i don't mind if it blinks fast honestly. as long as it works and doesnt cause further problems. guess i have to get the bumper first. actually first i need to dig the sand out that is stuck into the stock bumper right now.
Instead of buying the whole kit, as you don't need all those lights, you can just buy them individually. Just make sure whatever lights you buy, are the NAS style lights, as the euro tail lights wont fit the bumper. I'm waiting to hear back from my ins. company about it. When I went to the body shop, he told me I had to buy the bumper, and when i got it, he would reimburse me. Obviously, after the whole year long Bottorf debacle, Lauren isn't a fan me spending money on the truck.
