Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 07-01-2011, 12:51 AM
honda50r's Avatar
Senior Member
Alex 'Flash' Clark
Default Discovery 1 Rear Lamp Guards
So guys, overall; I recommend these. But, they're a pain to install. It's one of those things where you learn from one mistake and fix it on the next go around, except in my case there were a ton of prior mistakes.
Anyways, I got them installed tonight with help from my father after about 2.5 hours. I also installed my refurbished brush guard.
Don't worry, pictures will be here tomorrow!
__________________
-1998 Land Rover Discovery I, LE
-163,XXX miles.
-2" OME HD Lift Kit w/ 265/75/16, ARB, Winch
-Tennessee Rover Enthusiasts Community, T.R.E.C.
"Don't Rover Over!"
Old 07-01-2011, 02:25 AM
Gas Gas is offline
Junior Member
Looking for that !!!
Old 07-01-2011, 07:49 PM
honda50r's Avatar
Senior Member
Alex 'Flash' Clark
Before
After
__________________
-163,XXX miles.
"Don't Rover Over!"
Old 07-01-2011, 10:17 PM
Member
Aren't those the same lamp guards that come stock on some Alpine White discos? My disco came with 'em when I got it, but I have seen as many with the guards as without them. I've always wondered what the story was on those...
Anyway, I like the particular style quite a bit; they are aesthetically pleasing as well as durable.
__________________
1997 D1 Alpine
Old 07-01-2011, 11:34 PM
honda50r's Avatar
Senior Member
Alex 'Flash' Clark
Definitely. I got them sandblasted and applied some fancy primer and paint, they turned out well in my opinion.
I think they were a factory option? I'm not sure
__________________
-163,XXX miles.
"Don't Rover Over!"
Old 07-01-2011, 11:46 PM
collin Barrows's Avatar
Senior Member
Collin Oscar Barrows
i like them on, if you do keep them on make sure to check on them every so often. I've been told that people like ripping the guards off... go figure
__________________
Our fleet:
1960 Morris Minor Pick up (right hand drive)
The Tartus: 95 Disco with a full wilderness roof rack, 4 PIA lights on the rack, brush guard, with 2 fog lights, rear tail light guard, 2in Todco lift, Rhino Painted the cargo area, 5 Pro Comp 33in Mud Terrain Tires %75 tread, diff skid plate, and I'm only 18 ....
Bipolar: 2000 p38 Range Rover Brush guard, rear lamp guard, new grill, coil suspension.
Old 07-02-2011, 11:29 AM
Member
Default It's true...
Quote:
I have never had a problem with obstacles on a trail knocking out the guards. Every time they have come out was a result of some goofball molesting my rig. I should probably reinstall them so they are more people proof.
__________________
1997 D1 Alpine
Old 07-02-2011, 12:09 PM
wheelgarage's Avatar
Senior Member
Do you have the instructions? I bought a used set, and would like to know the process. For the past few days, I couldnt find anything on the web.
Looking for any help possible.
Thanks!
__________________
1996 Discovery SE7 - 5-Speed
Fully protected by Redline Oil / Lucas Grease
Terrafirma: MED Duty Lift Kit, Steering Damper, Castor Correct Radius Arms, Rear Cranked Radius Arms, Shock Turret Rings, HD Track Rods, Extended Stainless Brake Lines
Tyler-Engineering Steering Damper brackets; Polybush Orange Kit; OEM Swaybar Bushings; Adventure Roof Rack; Hella 500's; ARB Front Bumper
265/75/16 Cooper Discoverer STT; Terrafirma 16 x 7 TF100 Alloy Wheels - Anthracite
Work in progress......
Old 07-02-2011, 12:50 PM
Member
Quote:
Originally Posted by wheelgarage View Post
Do you have the instructions? I bought a used set, and would like to know the process. For the past few days, I couldn't find anything on the web.
Thanks!
Seconded.
Honda50r, if you wouldn't mind posting a brief walkthrough, I would be most appreciative. I'm looking to reinstall mine and it looks like you did a better job at it than whomever originally installed the guards on my rover.
__________________
1997 D1 Alpine
Old 07-04-2011, 06:09 PM
honda50r's Avatar
Senior Member
Alex 'Flash' Clark
I'm out of town and accessing online (I love the mobile version.) But I'll try when I arrive back in town.
Tags
1997, 1998, aid, discovery, forum, guard, guards, lamp, land, light, mods, painting, rear, rover, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
