OME Springs question
Finally pulling the trigger this month, I have a DII with new Bilstein's and would to go with 779 up front and 763 in the rear. I tend to carry quite a bit but am looking for a practical description of the difference between the 762 and the 763. I carry daily about 200lb and maybe 200-400 4 times a month and a full truck and roof rack a couple times a year just not sure whether to go with the 763. I will be getting a bumper but not for at least 6 months so are the 779 too heavy for the front.
If you will have a bumper and are thing about the 763's in the rear, consider going to the 751 front springs, keeping both front and back even and HD.
I would only mention, the 763 are pretty harsh when unloaded. 762 are usually more then enough for a heavy load.
The other thing to be concerned about will be your shock, they are 1/2" shorter then factory and the 763's may over extend them.
I run the 751 for the extar strength and height that the 779's can't give you.
So either go 779's and 762's or 751's and 763's, don't mix match.
That was one good explanation mike. Got some plans too. I think I will go for 751's and 763's. Thanks for the info.
_____________
chevy performance parts
_____________
_____________
_____________
Chrisinhouston
Feb 5, 2009 02:27 PM
