Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 03-24-2009, 09:58 AM
Senior Member
Default Factory Sub for rear door?
I can pick one of these up for relatively cheap. $85 I dont have one in ther rear door now, nor do I have the proper speaker plates to let the sound escape but thats easily fixable. My question is, are there connections behind the pannel to hook up the speaker? Thanks!
Disco II 2002
__________________
2002 Disco II
88,500 miles
Totally stock but searching to modify!
Old 03-27-2009, 07:46 PM
Member
I don't think you can put it there. You can fit it on the sides but I don't think there is a connection behind the panel. Its ok to correct me. this is my wild guess.
____________
If you ain't first your last!
battery charge protector
Old 04-01-2009, 03:30 PM
okdiscoguy's Avatar
Senior Member
pop your rear panel and see. My guess is the wires are there. Never hurts to look. My D1 has the amp attached to the back of the speaker assembly, and I am not sure about the D2. Might just be pre amp signals there.
__________________
RAVE
Good Oil
2003 Range Rover HSE with 2008 trim
2010 GLK 350 Mercedes
1990 VW Cabriolet - Lake car...
1997 Discovery SD-7 to put the boat in.
Tags
2008, factory, location, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
