If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
i am getting new tires, and am considering getting 265/70/16 BFGoodrich M/T KM2's. i was just curious if there were tires that anyone could suggest that would work out better for me. i live in south eastern idaho and only use my landy for minimal off-roading. i am a high school student and use it mostly in town. any suggestions? also if i get that size of tires with a 2" body lift, what kind of trimming will i have to do to my disco?
With a 2" lift, not a body lift, you can fit those tires with little or no adjustment. Don't go running off road with them unless you replace your suspension first, your truck will be too top heavy and cut your side walls.
That tire, by the way is really cool.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old Man Emu is probably the most recommended on this forum. If you plan on adding a roof rack or HD bumpers or anything to add more weight get HD springs and shocks from them. You can get a full setup at Expedition Exchange for a little over $600.
__________________
Mitch
"96 Disco SE7, stock for now...
thanks for your help. i looked at expedition exchange and i couldnt find any that give you any lift for the front. the 761 Front Medium-Duty Springs are the only ones that i could find that give the front any lift and that was only on the disco 2, and it was only 1". i was thinking 781 Rear Heavy/Medium-Duty Springs for the back which give 3"s but i cant find any for the front. anywhere else i can look?
Discolvr I'm going with 751s up front and 762s in the rear. That's a heavy duty setup (I'm adding bumpers and a roof rack) with a 2" lift. If you want a lighter weight setup you could go with 761 up front and 781 in the rear, which will still give you a 2" lift. Does that help at all?
For shocks I'd go with N115 and N44s. They're rated for HD loads and regular loads so they will ride fine whether you've added a bumper or roof rack or not.
Talked to a guy running that setup with no lift at all.
Mike, what do you mean by...
__________________
99 DII 110k - 2" OME - steering guard - sandy interior, salty
-------------------------------------------- http://roverine.blogspot.com - London To New York By Defender, Over Ice.
