If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
My Disco 2 idles rough in the morning after it has rained. A couple times the check engine light comes on but will reset itself in a day or so. Any ideas? I took it to the dealer and they cannot locate a code for why the light is on. Go figure. Yes, I did have it in while the light was on. OOPS, I was reading in the modifacation forum and should have switched to another for this post. I will try to delete it.
Reason: wrong catagory
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
You are ready for a 60K, has it been done yet, are you getting any fault codes?
When you go for wires, order the 8 mm Magnacor's and let us walk you thru installing them, you'll save around $450 in labor.
Look at my service list on the top of the Discovery section.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Thanks Mike. I am going to do the wires and plugs. Walk me through it. BTW, the link that was given on this forum for rebuilding my front driveshaft was excellent. I printed it and put it in my tool box for further reference.
