Self Installed Lift
+ 1 on this. I've done lifts solo on two discos and can do all four corners in ~2hrs. Just get the frame solidly on jack stands and use the factory bottle jack between the axle and the frame to push the axle down away from the spring perch. It would definitely go smoother if you disconnect the sway bar - but I've never bothered.
frankie_500 (03-10-2015)
I'm no expert but you definitely have to consider having stuff like a heavy duty floor jack (can withstand at least 3 tons), jack stands, and breaker bars to add leverage. If you don't have enough time to do it in one day, you will need ample garage space. Lots of sites that can guide you step by step. It would be good if you ask friends to come over and give you a hand. Good luck!
