If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Very important, especially if they are still factory.
How many miles on your truck? Specifically what springs are you wanting to install, the wrong one can lift the truck too high or not high enough.
By the way, why are you replacing the SLS instead of fixing it?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Reason: additional question
SLS seems too unreliable. They are deflated. Pump not working at all. Very disappointing for a vehicle with only 89k miles. One simple fix (springs) no more issues. Well, plenty more issues, it is a Landrover, but just no more with the air bags.
Should have asked first, I could have walked you thru the SLS issue.
At your miles, you would be a lot better off installing a Old Man Emu kit front and rear along with the adapter kit to convert the rear mounts to coils. Doing this will give you a much better ride, a more level and equal ride cause your current front springs, steering stabilizer and all 4 shocks have long since warn out.
__________________
Mike
