Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 02-28-2009, 07:21 PM
Junior Member
Default suspension installation
I am about to order the OME 751/762 & HD springs for my 01 D2. I have been searching thru the forum and found a lot of dead links for any tutorials for spring replacement. Does anyone know if a link that still works?
Basically I think the only specialty tool needed is a spring comressor, correct?
Mark
Old 03-01-2009, 07:46 AM
Send a message via Skype™ to Disco Mike
Mark, will you be running a front bumper and winch, if not, the 751 will cause the front end to be higher then the rear. If no bumper I would suggest a 779 front coil.
I can walk you thru the installation, check out the LRRF site for a good price.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 03-01-2009, 05:15 PM
Junior Member
OK. I will look into the 779's instead. I did have plans to eventually install a winch bumper, but don't have the cash for that modification right now since I also need tires, water pump, hoses, O2 sensors, etc....that I will be doing at the same time as the suspension. Thanks Mike.
Old 03-01-2009, 05:45 PM
If you are going for a bumper, go for the 751's and just sit a little taller till the rest of your work is done, save having to changes the coils again later.
__________________
Mike
Need Parts?
Old 03-27-2009, 07:54 PM
Member
Hey mike. Please post the step by step suspension installation. Maybe some will benefit if you post it. Thanks in advance.
______________
If you ain't first your last!
battery charge
Old 03-28-2009, 07:01 AM
I don't have one but can walk anyone thru it if needed.
__________________
Mike
Need Parts?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
