Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Modifications
Register Forgot Password?
Old 01-26-2009, 11:20 PM
Member
Default suspension replacement
ok. so i had originally planned on a body lift kit, but then decided a suspension lift kit would be better suited for my disco thanks to some good advice (you guys). but my problem is i have already payed for, and received my body lift kit. so once i replace my suspension can i still use my body kit, or should i just throw it in the trash?
__________________
1998 disco. stock... for now.
Old 01-27-2009, 12:01 PM
Send a message via Skype™ to Disco Mike
Default RE: suspension replacement
How much of a total lift are you looking for?
Yes, after replacing the coils and shocks, you can still do a body lift. At that point your truck will be more stable and able to handle the extra lift, you may though need to be looking at brake lines and drive shafts if you go too tall.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-27-2009, 11:09 PM
Member
i am not looking to go any more than 4". what is the max i can go and be able to stay away from replacing brake lines and driveshafts?
__________________
Old 01-30-2009, 08:51 PM
Fivespddisco's Avatar
Senior Member
Quote:
ORIGINAL: discolvr
What size body lift?
The break lines are only stretched as long as your shocks can stretch. But if you go more then 2 inch you should be changing your break line.
At 4 inches you should at least change you rear drive shaft to a U joint style and be looking hard at getting a better one for the front.
__________________
For expedition tested Rover gear Check out WWW.Lucky8LLc.com 716-898-8153
Old 01-31-2009, 07:44 AM
antichrist's Avatar
Senior Member
You mean 4" with the body lift? The body lift will have zero effect on your driveline.
If you are going with a 4" suspension lift, I will be very surprised if you can do it without modified radius arms and castor corrected swivel balls. When I was looking at a RTE 3" lift and talked to them, they said I may or may not be ok without those changes with 3". Some people are, some are not. With 4" I would be surprised if you were ok.
I am assuming the body lift is 2", since that is the most common. I would combine it with a 2" suspension lift (depending on what you are after) as that will keep your CoG lower and potentially save you a lot of expense.
If you decide to not use the body lift kit however, let me know, I might be interested in it for my Defender.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 01-31-2009, 09:34 AM
What are you going to do with this D1, especially with a total of 4"s of lift.
If you are doing it for off road, don't, instead go spend a long summer on the trails with other people and once you realize the lift won't get you over your favorite trail then make the other necessary changes.
__________________
Mike
Need Parts?
Old 01-31-2009, 08:29 PM
Senior Member
double cardin shafts front and rear. brake lines. Maybe think about a sensible solution and talk to several people. Rovertym treated me real well on my defender. Still needed the above from great basin rovers. You will create more problems that require more money the bigger you go. I couldn't see any need for more than 3 inches, but it depends on if you are for show or go. I did 3" and needed $900 in drive shafts and I'm still not finished fixing vibrations.
__________________
2003 HSE Disco
1994 arles blue Defender 90
Old 02-01-2009, 10:49 PM
Member
i was planning 2" suspension, 2" body lift.
__________________
Old 02-12-2009, 07:06 PM
Member
Quote:
ORIGINAL: discolvr
I think this is a good plan. You will not sacrifice to max of your handling and still get 4" lift.
_______________
volkswagen parts
Tags
defender, land, landrover, replacement, rover, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
