You don't need to worry about shorting out a battery connection underwater. It's only high voltage that's an issue with water. Or delicate electronics.
Also, if you want a battery mounted in the back, you're better off putting your starting battery in the back, and your winch battery where your current battery is. To properly supply a winch you'll need about 4/0 cable if you have the battery in the back, which would be pretty expensive.
Your starter draws less than 150 amps and that for only a short period. A winch can draw 300-400 for an extended time.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
