If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
hello there. i have a 1998 disco that i would like to put a 1 or 2 inch wheel spacer kit on but cant seem to find one to save my life. are there any websites i can visit that offer such parts? if so which ones would you suggest from experience? thanks. CWH
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
not lifted yet, but have a 2"er on the way. i am on regular 235/70/r16 but am moving up to 265/70/r16. i want to eliminate the "sunken" look of the tires.
i have seen theirs. but im just a poor high school student working part time. they are about the only place i can seem to find them, but im trying to find some for relatively cheap.
do they boost your performance at all? im still relatively new to rovers. ive only had mine since march. also, what is a good gear ratio that would work well off road, and as a daily driver?
The only reason I put spacers on my D1 was to stop my 265's (32 inch tires) from rubbing on the inner suspension on tight turns. My local offroad shop ( good Jeep place but little work on LR's) recommended them.
Disco Mike is right, unless you really need them you probably should not use them. You can now find some on ebay for the Rover so try there if you want some cheap ones, they will be about $90 pair. Spacers are fine if you are going to change to a different offset that will still equal the factory offset, I have done that on my BMW. Went from low offset to high for the type of wheel I wanted to run, essentially I did not change the distance that the wheel actually sits in relation to the suspension.
I would say of you really wanted then you should be fine for street use but be prepared for a possible issue when you wheel it hard.
__________________
1997 Range Rover Beluga Black
1995 Discovery 1
1999 Discovery 2
