Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > New Member Introduction
Register Forgot Password?
Old 10-06-2011, 09:05 AM
Junior Member
Default Greetings From Long Island, NY!!
Hello Everybody. I am a proud owner of a 1999 Land rover discovery series II. This is my first land rover but my father had a 1996 Disco 5pd! I look forward to contributing to these forums and getting to know you guys.
Old 10-06-2011, 09:48 AM
Senior Member
Great to hear from a second generation owner. You'll find a complete set of tech manuals to download for free below, it is called the RAVE (Rovers Are Very Expensive).
In the tech area of the forum, you'll find to-do list for new 2 u Discos, high miles Discos, etc. For your model you'll also want to look at the write up on rebuilding the propshafts. The front one starts "chirping" - just before it comes apart and pokes a hole in the transmission. Your temp guage is really an idiot light with a pointer, once it starts moving above 9:00 it is too warm. If you have access to a data reading scanner you'll want to compare meter to real coolant temp. The oil warning light come on at 7 PSI, meaning you can drive around at 9 PSI and not know it. After market oil guages are a good thing. Check fluids every week without fail, leaks can get a lot worse faster than you think. Change oil early and often, like 5000 mile intervals. A good diesel rated oil does a good job of cleaning this 1960's engine, Shell Rotella is one brand.
__________________
Old 10-06-2011, 10:39 AM
hilltoppersx's Avatar
Senior Member
edtatton
welcome to the madness! check out our club and forum if you plan on going wheeling or need local help with anything.
__________________
-Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Northeast Land Rover Club
www.nelrc.com
Tags
club, forum, furum, island, land, long, nyc, range, rover, york
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
