Hello from NY
Hello from NY
I was looking for a DII for a couple of months or so and just before Thanksgiving I came across a CL post for a 99, 117K runs but needs a starter - $1100. I called about it, the guy told me he is a wholesaler and bought it from a CT auction 1-1/2 years ago drove it to Long Island, he wanted to put a new front bumper on it and flip it. He never did. He wanted to sell it to make room. He tried to start it and smoked the starter.
So, I decided to take a look at it. The interior and body were clean and the starter just clicked. I mentioned to him that I was looking for a 7 passenger version. Then he said he has a 00 that has the 7 pass option at his house that his daughter used to drive, the only problem is that the transfer case is stuck in low. So, we take a look at it. It has ACE, SLS, sunroofs, winter package. He said $2500 for both. So, I picked up both of them for $2500 delivered to my house.
I haven't looked at the the 99 yet. I still have to replace the starter to see if I can get it running and sell it.
I 00 is registered and on the road. The transfer case issue was easily resolved. Initially I thought it was the solenoid. It was easier than that. When the shifter was in neutral, the indicator light didn't light a small movement of the shifter, lit the light and the case shifted into high.
I am working my way through the 60K list & some additional stuff
Done
- Front drive shaft rebuild (3 u-joints and centering bearing)
- SLS air bags (Arnott)
- Ft & rear diff fluid change (installed brass fill plugs)
- Tranny filter & fluid change w/ Lucas ATF treatment
- Oil & filter change (Shell Rotella T-6)
- Seafoam treatment (intake & oil)
- Techtron treatment
- Cleaned throttle body
- New battery (Advance Auto Parts Gold)
- Wiper blades
- Belt
- Front ACE sway bar bushings
- install cup holders on center console
- Watts linkage bushings
- ACE fluid & filter change
- PS fluid change
- BG 44K fuel treatment
- Replaced front wiper motor/linkage assembly (wipers didn't park)
- Kingsbourne wires and Bosch Platinum +4 plugs
- Belt tensioner
- TF MD springs, SLS spacers & +2 shocks (5/2/13)
- TF steering damper (5/4/13)
- 04 CDL Shifter (5/11/13)
- transfer case fluid change (5/15/13)
- Install 180 deg thermostat and flush coolant (6/13)
- replaced Rocker arms & shafts (7/27/13)
- replaced valley gasket (7/27/13)
- Oil filler o-ring (7/27/13)
- replaced Coolant hose (intake to throttle body) (7/27/13)
- installed 70mm idler pulley (7/27/13)
- throttle body gasket (7/27/13)
- Coolant pipe o-rings (7/27/13)
- Valve cover gaskets (7/27/13)
- Injector o-rings (7/27/13)
- replaced 80mm idler pulley bearing (NTN 6304) (7/30/13)
- Ultra Gauge (8/2/13)
- Hankook DynaPro ATM 255/70R18 (9/9/13)
- Calipers, R1 Concept rotors, TF +2 lines, pads (Akebono) & flush fluid (10/5/13)
- Spare tire carrier flip
- PS Return line (new), PS pump to box line (used) (11/22/13)
- Radiator (used) (12/22/13)
- Peak Global Lifetime coolant (12/22/13)
- Terrafirma TF809 sliders with tree bars (1/20/14)
- Replaced o-ring on the rear D.S. hub (6/12/14)
- Replaced both upstream 02 sensors (6/12/14)
- head gaskets, water pump, oil pump gears, cam (53229), lifters, springs, timing chain and gears, AC dryer, PS pump gasket (8/24/14, 109K)
- evac & charge AC 8/30/14
- installed downstream O2 sensors 8/31/14
- Plasti-dipped rims & wheel arches 9/7/14
- refurbed headliner w/ rattle can bedliner
To Do:
- install front drive shaft centering bearing spring. (Stupid me left it out when I rebuilt the driveshaft)
- install new gator on front driveshaft (ordered after I rebuilt it)
- find xfer case leak
- replace CDL switch
Done
- Wiper blades
- Belt
- PS fluid change
- Belt tensioner
To Do:
