Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > New Member Introduction
Register Forgot Password?
Old 10-17-2011, 12:26 AM
mpeters's Avatar
Junior Member
Default Hello from SoCal
Hi everyone.
New to this forum - have an older 96 Disco I'm bringing out of mothballs. Will be doing a lil work on her the next couple of months to get her back in shape and wanted to say hello.
/mike
__________________
96 Discovery, 158K
06 RR_Sport, 50K
Old 10-17-2011, 04:34 AM
Senior Member
You'll be wanting to download the full set of free factory tech manuals that cover owners, shop, electrcial, body and interior. Link below, called the RAVE. Also see our tech area of the D1 section, it has things to do for high miles vehicles, and common repairs step-by-step with photos.
If I was confronted with an engine that had "set up" for a while, I would be concerned with piston rings being frozen up. If vehicle has not been cranked would suggest remove all plugs, squirt in a modest quantity (spoon full) of thin oil, like Marvel Mystery Oil. Let sit 30 minutes. Crank engine without plugs for a few seconds. Wait. More oil. Let sit another 30 minutes. Crank again, maybe 10 seconds. When new plugs installed, run engine and you will get exhaust smoke, this will clear in a few minutes.
Your radiator is of the age and type (copper - brass) that it can be acid flushed and rodded out by a small indy shop. Sitting for long time, certainly without distilled water, not good.
__________________
Old 10-20-2011, 11:41 PM
mpeters's Avatar
Junior Member
Agreed. All good points. She's been cranked somewhat regularly even though it was mostly sitting. I just changed all fluids and replaced rear pinion seal last week. Just haven't put any road miles on it in quite a while. I will be rechecking the radiator - rodded it out a few years ago after running quite a bit of pond and stream water through it on a Dusy Ershim run when the expansion tank let go. But good point about checking that again.
And thanks for links to the rave manuals. I have the actual shop manuals, but don't mind having pdf copies for my pc. I have a few electrical demons I need to trace down - that's going to be more time consuming for me than anything right now.
/mike
__________________
96 Discovery, 158K
06 RR_Sport, 50K
Tags
forum, land, rover, socal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
