Series 2 bearings-where to buy?
Old 06-20-2015, 05:43 AM
GlennSalter's Avatar
7th Gear
Default Series 2 bearings-where to buy?
Please can anyone help.
I am new to the forum and have a series 3 which I now learn somebody has changed the original engine for an early series 2! I have had the crank re-ground to +0.20 on mains and +0.10 on big ends.
The engineers are being less than helpful and I cannot find replacement shells anywhere. I have tried all the usual suppliers ( Craddocks, Dunsfold, Fry's etc.,) but all either say they are the same ( they are NOT ) or cannot help as very difficult to find. The locating "lugs" are opposite handed and the shells are wider than standard series shells. the usual numbers quoted are RTC 172920 & RTC 2173010 but these are not correct.
I would be very grateful if anyone can help.
Old 06-20-2015, 06:26 AM
antichrist's Avatar
Maybe you can cross from PN here.
* indicates a new part that has not been used on any previous vehicles.
Old 06-20-2015, 12:31 PM
7th Gear
Thank you, much appreciated. I will now try to hunt them down!
Glenn Salter
Old 06-30-2015, 06:49 AM
drowssap's Avatar
try britpartssource on eBay, crossaxledcustoms.com or go to Glyco or federal mogul websites
Old 06-30-2015, 07:02 AM
7th Gear
Thank you I did manage to resolve it finally and tracked some down from *** & Turner engineering who were very helpful-much more so than the engineers who did the work!
Old 06-30-2015, 09:56 AM
antichrist's Avatar
Did the PN list I posted help at all? In case someone else is in the same situation.
Old 07-01-2015, 04:57 AM
7th Gear
Default Solution
Yes and no, thank you.
I went to Turner Engineering who were extremely helpful and identified the engine withing the first 3 digits of the number being read out! I have a 1958-1960 block with a series 2 head-great.
Any way they pointed me in the direction of *** & Turner Engineering in Southampton who were again very helpful. Although engineers per se, they know all about Landrovers and had stocks of my bearings on the shelf (all original in greased paper and boxes!), although be advised there are no more standard bearings available. However they make any bearing you from scratch-but at a price, although better than scrapping the engine.
John Craddock may be able to source but, as always it depends upon who you get on the other end of the phone.
South Cerney engineering in Cirencester also can provide if they do the work, but again expensive .
I hope that this helps.
Old 07-01-2015, 07:01 AM
antichrist's Avatar
Ah, yeah, didn't even think of Turner. Doh!
If anyone would know I'd expect them to.
Std bearings being NLA shouldn't be an issue. Oversize being NLA would be a bigger issue. No pun intended
Yeah, I was wondering if you had a "custom" engine. With Rovers that old it's pretty common since so many components are interchangeable.
rambo
Engine & Internal
02-22-2014 06:45 AM
bklahl
10-10-2006 03:11 PM
sanmigmike
08-24-2006 03:37 PM
rambo
05-17-2006 08:02 PM
rambo
05-10-2006 04:10 PM
Quick Reply: Series 2 bearings-where to buy?
