Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Off Topic
Register Forgot Password?
Old 10-27-2010, 03:23 PM
Junior Member
Default defender diesel 1972 startproblems
Hi,just bought a landrover defender diesel from 1972 and it have stand still nearly one whole year.
The old owner told me that the battery was,nt good so i bought a new batery today and starter go,s good but its not starting and i like to drive her to the garrage and get a new eu kontrol on her whitout to much work.
is it a option to dregg and jumpstart her?
please help me.
tanx
Old 10-27-2010, 04:45 PM
antichrist's Avatar
Senior Member
Defenders weren't build in 1972, so I assume it's a Series Land Rover. So yes, it would be fine to try to start it by rolling it, assuming the engine isn't seized.
If it were mine I would leave the fuel shut off, put it in gear and have someone tow you around some to get the oil flowing in the engine before you then turn on the fuel to try to start it.
Make sure the coolant level is good before starting it.
__________________
Tom Rowe
Four wheel drive allows you to get stuck
in places even more inaccessible.
62 88 reg
67 NADA x2
74 Air Portable - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 10-27-2010, 09:28 PM
Philip Lawrence
Send a message via Skype™ to Spike555
If you have excess water or air in the fuel lines it will not start, and sitting for a year both of those are very possible.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 10-28-2010, 05:14 AM
antichrist's Avatar
Senior Member
good point Spike. Unfortunately I neglected to mention the obvious (to me) to drain and replace with new fuel.
After a year the diesel is likely full of bacterial scum anyway, unless a bio-cide was added.
__________________
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 10-28-2010, 07:50 AM
Junior Member
Fantastic!!!
We roll the car for some meters and just in the second gear.
after returning start direktly!!!
Lots of white smoke and little bit black for 15 minutes.
Now it runs but have to chance the clutch but the main problem is done thankx alot!!!
Regards
Old 10-28-2010, 04:17 PM
Philip Lawrence
Glad to hear you got her running.
__________________
www.marshill.org
www.20liters.org
Old 10-28-2010, 10:18 PM
Danny Lee 97 Disco's Avatar
Senior Member
Does it have a hand crank for the engine? A friend of mine has an ex-MOD series that does have a hand crank as well.
__________________
HAPPY TRAILS TO YOU FROM.
Danny Lee 97 Disco
Driving MEANANDEROVER
Might be a REDNECK in a Rover
Just Don't Flip Your Rover Over
See my Rover Pics: http://community.webshots.com/user/DannyLee97Disco
http://www.youtube.com/watch?v=dZz2qlKeAJk
http://www.youtube.com/watch?v=MYyxc...eature=related
THESE ARE FOR THOSE WHO I OFFENDED
Old 10-29-2010, 07:26 AM
antichrist's Avatar
Senior Member
The diesels had hand cranks as well, but it's not particularly fun to do because of the high compression of a diesel.
My Series petrols I hand cranked on a few occasions. One of my 6cyl I did for over a month in a Vermont winter in '80 because I was broke and couldn't afford a starter solenoid.
__________________
Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
Old 10-29-2010, 07:16 PM
Philip Lawrence
Its a bitch hand cranking a engine petrol or not, we had a 1936 Allis Chalmers with hand crank and if you forgot to charge the battery you hand to hand crank it.
Do that once or twice and you would'nt forget to hook up the battery charger ever again. (it didnt have a alternator, it ran off a magneto but it also had a electric starter so the battery was used for starting only)
__________________
www.marshill.org
www.20liters.org
Tags
1972, 72, air, defender, diesel, fuel, land, landrover, rover, startproblemer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
