Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > Off Topic
Register Forgot Password?
Old 12-26-2010, 10:08 AM
Senior Member
Send a message via Yahoo to Alex J
Default Way off topic question
Does anyone here do home HVAC work? I have a HVAC system that has an automatic air recirculation feature which would be nice if it worked properly, but it is constantly staying on. If anyone could suggest which wire I could try to undo from the control panel circuit board to turn this off that would be great.
__________________
2002 D2 SE Westminster Edition
Factory brush bar, PIAA 520 ATP lights, Osram 100w fog light bulbs, Osram 80/100w headlight bulbs, D1 wiper conversion with PIAA silicone wiper blades, 245/75/16 DuraTrack's, MagnaFlow Muffler
Old 12-27-2010, 05:19 PM
yloDiscoII's Avatar
Senior Member
Don't have a clue about the wiring, but do you have a timer attached to yours? It might have gotten goofed up?
__________________
Rob
2002 DII Kalahari (139K)
“We do not accept that ours will ever be a nation of haves and have-nots; we must always be a nation of haves and soon-to-haves”
Old 12-28-2010, 01:56 PM
Senior Member
Quote:
Its all in the control panel. I'd just install a different control panel but its a dual zone system for my 2 story house.
__________________
Old 12-29-2010, 10:11 AM
yloDiscoII's Avatar
Senior Member
Quote:
Sorry man, no clue, I figured someone smart might have chimed in by now. Mine's a on a timer so that would have been the first place I would have checked...maybe there is a HVAC Enthusiast Forum out there somewhere you could join Good luck!
__________________
Rob
Old 12-29-2010, 12:31 PM
Chris-bob's Avatar
Senior Member
The fan itself(assuming you have access to it) should have a connector you can unplud if you need it off for a few days until you can find the problem. Most likely you have a problem with a temp switch.(I'm only quessing since all I work with are oil furnaces and wood stoves up here...we don't have A/C up here....so no dual zone stuff)
__________________
1996 Discovery SE7 stock V8 with 5 speed manual. 85K original miles.
Link to download the RAVE http://www.landroverresource.com/rave.zip
The smaller workshop manual is here.
http://www.landroverresource.com/doc...hop_Manual.pdf
Originally Posted by tornado_735 I keep motivating myself saying that some poor bastard had to do the very same thing during the Camel Trophy and that I'm no different from him.
ECU pics -
http://smg.photobucket.com/albums/v6.../Land%20Rover/
Old 12-29-2010, 01:48 PM
Senior Member
I'll probably just call an HVAC person when I have some extra cash. The issues is I can't disable the fan because it is the same one that runs to circulate the warm air when the heater kicks on. I just need the recirculation feature disabled. I'm considering installing a "dumb" controller that only samples the temp at the controller and has no recirculation feature.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
