Other All other Land Rover vehicles.
Mud under the doors Discovery 2014
Old 10-30-2014, 12:54 PM
MKO's Avatar
MKO
MKO is offline
3rd Gear
Default Mud under the doors Discovery 2014
After hunting tour, I discovered that there is a significant mud clumps under the door rims accumulated that are only seen when the doors are open. Anyone has experienced the same problem? Is that normal? If not (and I suspect it shouldn't be normal) what can one do about it? The dealer said that this is normal, but I suspect it shouldn't be.
Thank you for any response.
Old 10-31-2014, 09:14 AM
Jagfixer's Avatar
Mud is worse than water, you can see where you have been. Is it below weatherstripping? If so it is normal.
Old 11-03-2014, 03:32 AM
MKO's Avatar
MKO
MKO is offline
3rd Gear
Thank you for your reply! Yes, it is below weatherstripping, the part that goes under the car body. Any ways to prevent it? Or perhaps one shouldn't because it has a purpose (I don't see what that purpose might be though).
Thanks again.
Old 11-04-2014, 09:18 AM
Jagfixer's Avatar
The weather stripping keeps water and the mud out of passenger compartment, anyway supposed to. Dirt lower than weather stripping is normal. Make sure you keep door drains cleaned out and clear of debris.
Old 11-05-2014, 01:08 PM
MKO's Avatar
MKO
MKO is offline
3rd Gear
Thanks Larry! Will do.
disco5000
LR4
06-26-2014 03:38 PM
TRIARII
Sights N Sounds
13
02-16-2014 11:09 AM
rezzrover
05-07-2013 06:02 PM
wynhd
08-28-2012 11:33 PM
Spencerfitch
12-17-2010 10:48 AM
Quick Reply: Mud under the doors Discovery 2014
