Series III Clutch piston??
Hi guys,
I just bought a 1979 series III RHD 88 diesel Rover. I just got it running tonight with a little luck and bleeding of the fuel lines. However the Hydraulic clutch is giving me problems. I've bled the line running from the reservoir to the piston on the tranny. I push the pedal with some force and its met with some resistance, however the clutch doesn't engage. I can feel the gears with the stick and I know the clutch isn't engaging.
Any suggestions or pointers on how to trouble shoot/ fix the piston for the clutch?
I'm new to series rovers.
I found out that once you engage her in reverse "with or without" the clutch, She will go no matter what.
did you figure it out yet? when was it run last? sounds to me like the clutch is rusted to the fly wheel so you cant disengage the transmission. Sometime if you start it in gear and just drive it around it will become unstuck. But you need a big pasture to drive it around in. Maybe some one on here can send me in the right direction. I have a series IIA That I have owned for ever 1970 88" a got it out of the factory and took it to Africa central America and up to Alaska. It hasn't run for 15 years and I want to start to get her going again. two questions. is this the best forum to talk to people with series rovers or is there one just for us series people somewhere? the other question is where are you finding your parts? Thanks let me know how you fixed your problems. I will have the same problems.
According to the last owner he had it running and driving about 5 years ago "I'm not so sure about that". I wound up swapping out both clutch pistons. I still cant free up the clutch on the series 3. I'm actually working on my Series 2A for the winter.
I'm not sure of a better website for series, but I'm sure you can find a more active one.
I've been getting parts from a good company over here in the north east "Rovers North". Atlantic British is also a good supplier of rover parts. I believe Atlantic British partnered up with another company located on the west coast.... a "British Pacific". Correct me if I'm wrong guys...
I don't see any reason why parts cant be shipped?
Thanks for the advice with the series.
rovernoob
07-31-2015 10:52 AM
georound
11-23-2004 11:54 PM
