02 P38 RR oil cap gasket question
Old 01-08-2011, 01:24 PM
RROJ's Avatar
Default 02 P38 RR oil cap gasket question
Just the other day I went to check the oil and wanted to add some since it needed just a small amount. When I went to unscrew the oil cap I noticed it had a foam gasket which tore when I removed the cap. I called the stealerships in the area and they said this gasket was needed to keep the right amount of oil pressure.
Have any of you noticed this gasket and do you believe the truck can run effectively without it until I can get it replaced? Is the stealership speaking the truth? The oil cap fits nice and tight even without this foam gasket. Any comments are welcome.
P.S. Happy New Year fellow Range Rover enthusiasts!
Old 01-08-2011, 09:46 PM
handsome rob's Avatar
huh that is a good question. I am willing to bet that the loss in pressure is not that great enough to cause any damage. Also if you are really worried you can get some gasket material from any auto store and try to make it work. I really do not know the answer but I know I have run the engine with the oil cap off in the drive and have not noticed anything detrimental.
Old 01-10-2011, 10:24 AM
krazzz's Avatar
I think that is 100% bull. The crank cases are ventilated on these things (as with almost all internal combustion engines) so they don't build up any significant pressure. It scares me to think how much oil these trucks would leak if the cases were under any kind of pressure. Probably couldn't drive to the end of my driveway before my oil was all gone.
Old 01-10-2011, 12:07 PM
I agree with Krazz, I think they are just trying to sell you something.
Old 01-10-2011, 04:12 PM
RROJ's Avatar
Thanks for the responses guys. I think I will keep my money for something RR really needs.
outdoor7or24
12-22-2014 09:31 PM
mike111
06-02-2014 08:58 AM
joefresso
04-16-2011 05:49 PM
bookerbr
01-12-2009 11:21 AM
mge_1
08-17-2006 11:14 PM
Quick Reply: 02 P38 RR oil cap gasket question
