03 HSE Radio Non Existent
Old 08-22-2010, 08:39 PM
grussell's Avatar
Default 03 HSE Radio Non Existent
Radio does not turn on or work. Nav works, on board computer works, no other problems. Radio just stopped working.
Old 08-24-2010, 06:31 AM
Rovin4life's Avatar
check out the back for corrosion in the nav unit and the radio and the amp. if the stuff has power and ground then you need to swap out a known good amp and or radio unit.
Old 08-27-2010, 06:35 PM
grussell's Avatar
Is the radio unit in the dash or in the left rear qtr compartment?
Old 08-29-2010, 06:04 PM
grussell's Avatar
Well, took the Rover to a stereo shop and they said they diagnosed a bad radio unit. So, I went home and pulled the radio unit out and was going to order one from car-part.com. I noticed a small 10a fuse and pulled it out and held it up to a light and it looked good, but for kicks I tested it with my ohm meter, viola, bad fuse. I replaced the fuse and put her all back together and the radio works!
Old 08-29-2010, 06:51 PM
lordmorpheus's Avatar
Awesome! This is a good example of why its always best to perform a thorough test (checking resistance on the fuse) rather than just using observation (the fuse looks good). How much money did you save by taking an extra 5 seconds to properly test the fuse?! Whatever the amount, I'm sure it's a good time/dollar ratio!
Old 08-30-2010, 12:10 AM
LRScott's Avatar
Good job! Always start with the most simple and CHEAPEST thing before moving on to the big ticket items. Well done. I am guilty of starting with the most expensive thing (worst case scenario), it never pays off.
dogstarsix75
04-24-2020 01:33 PM
lvshust
08-21-2018 02:29 PM
moocowman
08-31-2011 04:07 AM
southfloridadiscoII
06-28-2009 11:03 PM
Quick Reply: 03 HSE Radio Non Existent
