1995 4.6 hse
I am assuming you mean the "noises" the car would make if you were turning the ignition and using the turn indicators... If you do not hear anything and everything is otherwise functioning normally. The speaker that normally makes those sounds might be damaged or disconnected. I am not entirely sure where the speaker is, but it is probably in the instrument cluster. At least thats where the sound is the strongest. In all honesty it might actually be nice not having your rover yell at you for every little thing. It sounds like mine is going to launch a weapon when starting.
I think I remember seeing something on rangerovers.net about the speaker and how to disconnect it so you do not get the annoying beeps. Your indicators will be a relay sound I believe and not a "speaker" sound. Unless I missed what you were saying that it does sound but it so fast you cannot hear it or you miss it.
Good to know, thanks. I knew it sounded different but I never really payed attention to where it comes from.
CPTLOU
02-03-2014 06:06 PM
danohameed
03-08-2010 03:54 PM
Stickestar
Appearance & Camping Set Ups
12-13-2006 03:25 AM
