1998 P38 Alarm Issues!
Hi all
Is there anyway to disconnect the immobiliser and or the alarm??
I suspect my P38 has multiple alarm issues.
I bought it with most of them (one key is not 'coded' to the car and central locking does not work) and use the key to operate it. I have to leave it unlocked at work and yesterday I noticed the rear lights had come on. I locked and unlocked the car and they went off.
Today I went to start it and nothing happens.
I'll check other possible causes tomorrow but I strongly suspect the alarm system has decided to leave the immobiliser on!
Is it safe to try to jump start it to test the battery?
Any help greatly appreciated!
Thanks!
I have had the alarm error in the display every time I start it since I purchased it and it has continuted to start ok.
I don't even know where to start sorting out the alarm issues as I don't know the whole back story.
I have one key (labeled key 1) that does not appear to be coded to the car and one (key 3) that is but does not work.
I'm just wondering if all these issues are the reason why it has now decided not to start and if there is anything I can do to overide them??
Could be it?
This is my exact issue found on Rangerovers.net..
"The only error message I get is when I set the alarm and try to turn it over: "Engine disabled use remote". The Engine light comes on and goes off before I try to start it. The remote will unlock and lock the doors, except the passenger side front door and arm/disarm the alarm. I have tried the generic EKA procedure #1515 with no avail. When turning the lock, the side lights will blink so I think it is recognizing the input although the lock seems to be a little loose. We have tried unhooking battery and hooking back up with key in #2 position as well. Fuses and relays seem to be fine. We have replaced the remote batteries and made sure the vehicle battery is fully charged as well. When we turn the key, there is a click noise from the controller under the passenger side seat and that is about it. I feel it is in the alarm system but am having absolutely no luck!"
A week later Brian wrote back in with the following news: "We took the fusebox apart and repaired it from the info you provided and it worked! We found all kinds of solder joints that needed repairs and once we repaired them the Rangie started up and runs excellent. I was very grateful that it was not the BECM!"
Looks like I might need a new fuse box
Will keep you posted!
Oh thanks! That might be handy to know in an emergency. Getting it out and back into the country would be interesting though! (I'm in Russia)
fivehands
14
01-16-2021 01:54 PM
kevinocall
06-02-2015 01:37 PM
Russian_Rover
11-26-2012 06:12 AM
red rockett
13
03-28-2008 06:53 PM
